Have others experienced not being able to use the Naim app on iOS? Has something gone wrong with the latest update? I’m on 14.2
Can’t connect to my SU and just get the another app connected, but I don’t have the app anywhere else…
Which streamer do you have? Have you tried rebooting your hardware? and probably me being stupid, but what’s SU ?
SU is SuperUniti.
If you restart everything then it should all work fine. There is no problem with the app in IOS 14.2.
Best
Sorry, yes it’s the SuperUniti. A power off and on got it going again.
Bit strange I’ve not had this happen before.
Thanks for the help.
