This is a pic of one of my terminations, obviously it needs a little trim, but it took a while to even get here.
Vandamme 6mm Studio Blue. I used a Weller 230v soldering iron with a 2.4mm straight chisel tip. Solder was 40/60 lead/tin.
Tin the wire first and line the slot with solder. Try and keep the cable ends pointing downwards so as the solder wonât run up the inside of the insulation. I used a little dab of La-Co flux paste to aid flow, then took the solder to the joint until it was full. Clean off the joint afterwards with flux cleaner
I had a faulty opto-coupler in my nait 5i and it done the exact same thing, it cost âŹ250 to repair a few years back now.
Not with A5, youâll never get it in and donât twist it, the Weller ironâs good though.
Where thereâs a will⌠To be honest, the slots arenât big enough to take 6mm cable so a little fettling is required
