I know these are optimally backed by a high mass wall. How about a glass wall behind, with structural wall posts directly behind the speakers (6"x6")? Don’t bother, or maybe ok?
All you can do is try. I used to live in a flat with a glass wall on the side with no issues, the wall was pretty flaky too. You live with what you have!
No, you need to move into a warehouse conversion with walls at least 6 feet thick. Nothing else will do.
A French castle - but that will be a bit cold this time of the year.
