Another Speaker Cable Question
Thanks for the advice Halibut…
I have a pair of Tellurium Ultra Black II 2x2m which I used to use between my NAP 250DR and Kudos 606. I sold my 250DR and I’m waiting for a new 300DR. I did not have any problem with 250DR and the 2m of the above speaker cables, however I’m a bit afraid to the result with 300DR both in SQ and damaging since I have only 2m and getting something more is too much expensive unless I take something cheaper like Kudos KS-1 but I really like the tidy of my 2m cable.
Hi
I found the K20 ‘a bit dull’ - just my opinion :relieved:
It’s worth noting that while very similar, K20 was not identical to NACA4.
I am still using Naim A4… :slightly_smiling_face:
I know of Linn K20, but have never ever used it. But I know its construction is similar to NACA4.
K20 is just an option - for those looking for a NACA5 alternative - for less £$£$…
I had the Naca 5 then Apertura tiny, which I found slightly better and more refined, with Naim amps from the beginning.
Recently I purchased the Audience SRX. Oh boy, what a difference. In all aspects. Bass, prat, soundstage, textures, dynamics….Whouah!
