The Uniti 2 has two mono sub-woofer outputs. Noting that most sub woofers have a standard L/R RCA input, are the Uniti outputs designed for powering two sub woofers or one mono feed per channel? I’m a sub-woofer virgin I’m afraid.
Some subs (mostly more basic models) onky have a single RCA input socket, so in this case the mono output from the Uniti is ideal.
If your sub has two RCA inputs, it will sum the two channels into a mono signal that the sub can use. Alternatively you could use the pre out DIN socket.
If you use two subs, connect each one with a mono cable.
Another option to consider is to use a high level connection from the speakers, which can work better with some subs such as Rel.
