Anyone compare an old Rega P9 to P6 or P8?
I have one of the first Rega P9 turntables. I wonder how this might compare to the current P6 or P8?
Interesting question. I had a P25 from 1999, initially with a mundane Rega MM cartridge. I bought my daughter a P6 with a HOMC cartridge. That blew the P25 away, but a lot could be the cartridge.
The easy answer here is to get a pre-owned P10 and a decent MC cartridge. That way, you can continue to have that nice ceramic platter.
Not do easy. I only purchase from my dealer and I doubt he has a used P10. Secondly the P10 has a full width PS if I am correct. The Neo PS, is much slimmer and easier to place on my limited rack space.
It’s half width:
I’d expect a P8 comfortable beat old P9.
My Rega P9 is on the top shelf of my rack. The P9 PS is on the shelf below the P9.
The P9 has a full width PS which means there is no room for the Naim NCV TT on the same shelf as the Rega P9 power supply. I could put the Naim phono stage on the bottom shrlf, but then I would not have room for an NPX 300 unless I got new racks.
So you need a rega with a half size power supply. Is that you are saying ? Then the psu and naim phono can go on the same shelf?
The old Rega P9 was/is a good TT and against the modern range I would put it a the level of the P6/P8 or above but not quite as good as the P8 and the P10 is more likely to beat it with the better tomearm. I think a new P8/P10 would be a good upgrade and should be able to sell (if you wish) the P9 on eBay and the like for a good contribution to a new TT.
YES. Exactly.
Agreed a P9 would make good money on ebay.
Not sure that the RB 880 on the P8 would feel or sound as good as that RB 1000 on the P9?
Yes I think your right. I was thinking the P8 might beat it but the arm made me think again. In my view a lot of what makes the P10 better is the RB3000 tonearm and the p9 arm is pretty good.
I just looked and there is a P9 for sale on eBay a the moment for a £1500 asking price obo. I am not sure they will get that but it should go for for good money.
As is the ceramic platter.
Arm and platter are a lot of what the P10 brings over the 8.
Swapping a RB303 for a RB3000 made a huge improvement to my Michell Gyro SE.
I agree the platter and tonearm of the P10 is what it is mainly about but I think the arm is doing a lot of the heavy lifting. A friend of mine bought a P10 to upgrade from his P8 and before he sold it we experimented a bit for science. He swapped the RB3000 + cart onto the P8 and it really improved it. I would say not quite on a par with the P10 but it made it much closer.
I replaced an RB600 for a Audiomods Series 6 on my Gyro and it has made an excellent upgrade in sound quality.
It came with rb900, later on rb1000
The P8 is more dynamic vs the P9. But the P9 is the nicest tt Rega have ever made.
I had the RP3, P25, P9, Rp8, Rp10, and now P10.
If you, I would buy a second hand RP10. But I know you buy only new….
Someone knows their Rega’s here !
Are you not settled with your system? You’ve had a lot of threads looking to upgrade headphones, add a headphone amp, change the amp, change the streamer, and now change the turntable.
Maybe you should either be happy with want you have, or swap everything out to a new simpler quality system?
I’m very happy with what I ordered. That is not the issue. If I ever want an NPX300 for the 332, I either need a new rack or get a P8 which has a half width power supply. If I got the P8, then its Rega Neo PS and the Naim phono stage could share the same shelf. I may just eventually get a new rack. There is nothing to fault about my P9. I even think its tonearm is better than the P8 tonearm. I will keep the P9 and probably change to a Rega MC.
I personally wouldn’t upgrade a P9 to anything below the P10. Especially if you’re not running a MC on the P9.
