These are Swiss speakers with aluminum cabinets, extremely expensive. Several reviews and positive comments are available online, but I’m wondering about compatibility with Naim amplification.
A NAP250 will drive pretty much anything even down to 2 Ohm impedance.
Stenheims have high sensitivity and a load any Naim amp can handle. So no isdues about capability. Whether there is synergy or not I cannot say.
Good luck.
Hans
Thanks to both of you for your replies. I realize that the Stenheims have high sensitivity, 93db or so, and are easy to drive; synergy with Naim is my main concern. Art Dudley wrote reviews of two models in Stereophile, and I believe he was assigned the task because he only owns wimpy tube amps that, on paper, should be a good match. However, i notice that dealers and others are using fairly powerful SS amps–Soulution, for example.
