Openreach have just installed full fibre and an ONT
They also kindly setup my Deco X50 MESH.
The engineer has connected from the ONT to my Plusnet HUB2 router as a modem and then an ethernet cable to the main DecoX50.
Everywhere I’ve read on the internet seems to indicate that the X50 should plug directly into the ONT.
So I’m a bit confused, do I need the Plusnet HUB2 acting as a modem, or can I plug the X50 directly into the ONT?
e.g.-
No, you do not need a separate modem with full fibre and an ONT (Optical Network Terminal). Here’s why:
With full fibre (FTTP), the ONT acts as the interface between the fibre line coming into your home and your home network — essentially doing the job a traditional modem would do.
You simply connect your router (or a mesh system like the TP-Link Deco X50 you’re viewing) directly to the ONT via an Ethernet cable.
The Deco X50 supports this setup — customers confirm they’ve connected it straight to their fibre ONT without any issues.
So the setup would be: ONT → Ethernet cable → Deco X50 (main unit), and then the additional Deco unit(s) extend your mesh network wirelessly or via Ethernet backhaul.
I bought a similar setup a few months ago and it has worked flawlessly so far. I use it as a 4G router as I bought the model that has this option built in, plus another two X50s to give mesh coverage around the house.
The main unit has a WAN port, so I can’t see why it wouldn’t work connected directly to your ONT without using the Plusnet router in between. In the past I have always kept the ISP supplied router in place on the basis that it is supported by your ISP so it’s more likely to work reliably, and it will be easier to get support from them if you have any problems. I just decided to try removing it this time to keep the electrical clutter to a minimum and it hasn’t been a problem.
I suggest you give it a try. If you have problems you can always stick the Plusnet router back in.
Assume you are with Plusnet then? If so yes you can connect direct to the ONT but you need to configure the X50 to use PPPoE and your credentials for it to work.
I have Deco X60’s rather than X50’s but I’m sure they operate the same. I was supplied with a talk talk router which I now don’t use, but do use my old Asus router which is faster.
You can plug direct into the x50 and it will act as your main router (with the Caveat you are okay setting it up with your credentials) but you don’t haveto or need to. I use my old router to connect anything wired back to the internet but route all wifi through the Decos. So my hifi is on the wired router side via a couple cicsco swithches, everything else (phones, Tv’s, Computers) is on wifi through the decos
I think I’ve cracked it following advice given above.
Ethernet cable from ONT into Main deco x50 then I’ve used another ethernet cable into the back of my Linn DSM. I’ve put the other X50 in the hall and seem to have a very strong signal throughout the house.
It works most of the time, but my mobile does loose contact with the Linn even though it’s within about 4m and in the line of sight, so maybe some tweaking is required.
But at least I can control it most of the time.
Do you have ‘wired backhaul’ from one X50 to the other? Not essential, but generally best practice where possible.
Are you running the Deco app on your phone? This will identify any poor connections so you can see where they are and potentially address them. Possibly you need another X50 somewhere to give better coverage around your house.
Thanks Chris - I had to look that up, but no I don’t and I’m not running a cable around my lounge and into the hall.
The Main Deco and ONT is about 1m from my system, so I have an ethernet cable going from the Main X50 into the back of my DSM.
When I listen (with mobile Linn app to hand) I’m about 10ft from the main Deco which is in line of sight.
The Deco in the hall is just sitting there with no connections - I feel a bit sorry for it
Yes I have the Deco app on my mobile - I can’t see any notifications about poor connections and the wifi signal strength is very strong at around -40db
Some advantages to your set up, I think, as you are able have the Deco acting as the DHCP server rather than a separate router connected to the fibre. I had to put my Deco (connected to a router with no configurability to pass though the data stream) into AP mode to support multiroom streaming.
