Not found topic specifically about this latest version of App 2.5.7, although its been out a while now.
I just prefer the interface/selection/options on the previous App. Previous app updates tended to keep to the same profile.
Graphics (menu) not as clear to me on new app.
Settings require two selections rather than the previous app which from memory initiated on one “button” press. Why have to select twice?
Track selection and its display also seems different, perhaps I have just not used it enough to learn its idiosyncrasies. Won’t bore you with complicated life, but using the Core is a luxury.
Perhaps I’m just an old man, that does not like change!
Using android tablet (only a few years old)
Views please - If I’m not the only one, perhaps Naim might take note.
I believe you are referring to the Core’s firmware? Version 2.5.7 introduced no changes such as you mention, so it’s hard to know what you are referring to.
I suggest you turn your Core off and disconnect the power for 30 seconds or so. And then plug the power in and let it start up. Also restart (by which I mean turn right off and then turn again) your Android tablet. Hopefully you will then find everything is how you expect it to be.
If you still have a problem then I suggest you phone or email Naim Technical Support. Naim staff don’t routinely read posts in the forum, so if you want them to help or even just note your comments, you need to tell Naim Technical Support.
I’ve had this issue where sometimes multiple “taps” are needed to start a song selection. Then I realized it probably had to do with updates defaulting to this choice in settings. Taps for Options: as shown in the picture is what you want for single tap play.
Hi David
Sorry TITLE and text should read APP version 7.0.1 - can someone correct?
Hi Quad57
I should have qualified the Graphics/appearance, I mentioned was concerning the “System Settings” - titles in bold seem to clash and what with the lighter text, causes me clarity issues - perhaps I have some form of dyslexia!!
The double tap I was mentioning is the settings selection - seems illogical to me to tap “three dots” to achieve another toggle for a “setting” tab only. Perhaps the android app works better on Apple.
This morning after realising my error about David’s post APP/Firmware - I thought I would try and repeat the issue I get when I select a track from an album and a first selection I get a screen that seems basic with heading “Newest Music” with only “X” to clear it in top left corner and then on a second selection “play” of another track and all seems ok with what I would call the normal screen that allows a toggle, play order, track info etc. Then another time of a new track selection I get “Not playing” screen with the original basic screen mentioned above. Try again and all appears normal - just very confused. Perhaps resetting APP might clear this apparent glitch?
