I had the old app installed on an Android phone. I installed the old app on a new Android tablet but the playlists are different. I can’t see my ones from the phone.
When I look on the phone, they are still there.
Playlists are stored locally in the app on the device that runs it. There is an advantage to this if multiple users want to use the same streamers and control their own playlists, although it may not suit everyone.
You can manually transfer a playlist from one device to another, although any further changes will not be automatically transferred across in future.
Thanks for your quick reply. That makes sense.
I just installed the new app and I notice that the old playlists are showing.
So all happy.
Tks
