I use a USB drive on the Muso. The music file directory structure is artist/album which I assume is the normal arrangement. I have noticed that a few artist folders (and album contents) are duplicated on the app. Seems to be every 100th or so. The files play fine so not a biggie - just odd. If I delete the duplicated folder it simply duplicates the next in line. Anyone else experienced this? Is it an app bug or is there a fix?
I saw the similar points raised in the closed NAS share topic but I don’t think this is a recycle bin issue as it seems to be related to number sequence.
Thanks for the comments. I have deleted the recycle bin a few times (windows seems to want to put it back). What makes me think it is a bug is that if I delete the duplicate, the next folder in sequence is then duplicated. Strange.
I only noticed it by chance. The duplication seems to be consistent every 100 or so folders. I don’t know if the app developers would be interested?
