App is displaying a persistent message “24 tracks were added” across the foot of the screen, grey background with white typeface, regardless of which album was last selected and regardless of how many tracks were last selected.
Does not affect the ability to select new playlists, play them and delete them, but neither does it go away again.
Do I need to delete the app and download the current version? Come to think about it, why would the current version not have updated already by now?
Not only does it not cause problems to download an app update onto the existing app, but you will lose any customisation you had if you delete the old one first. The updates are designed to update what is already there.
You can set your phone to do automatic app updates if you want. It’s a setting in your phone. Nothing to do with Naim.
See, that’s where I get confused. When I navigate to > Settings > App Store on my phone I see at once it is already set to “Automatically install new app updates”, hence my questioning why this has not already happened as it has always up to now.
You can pretty much assume that any software these days is full of bugs. Updating is recommended as it is usually intended as a fix (notwithstanding the inevitable fact that it will introduce new bugs)!
