Just bought an Apple A1619 adaptor - which will work fine with my iPhone X. The phone will charge on pass thru; the Phone can ‘see’ a USB stick if I plug it in. All Good…
However… with my iPad 6th Gen, the iPad will not charge (tried several leads and both iPhone and iPad chargers) - and the iPad says insufficient power with the same USB stick connected. The iPad charges fine with the same lead/charger if connected directly.
I tried a USB Hard Drive and my DSLR (Nikon D7000) - but neither of these would work with my iPhone.
Is it me… or my iPad…? Or is my A1619 not playing correctly…?
@Kevin , @ChrisSU , @davidhendon - Thanks. My iPhone updated itself earlier today - and will work with a USB stick, and charge, via my A1619. Which suggests its OK…? Perhaps asking too much to power a USN HDD…? But would have thought a DSLR would be OK…? Maybe just too old…?
Is there a similar update for the iPad…? Checking… Yes…!!! Lets try it…!!
This could be it… Thank you…!!!
(f4&kin software… )
PS. My iPad is ‘new’ to me and I didn’t have the Settings icon visible… So I didn’t know there was an update… Will fix this, once the update is done. And I will report back if the Charging issue is fixed.
Mine charges OK, albeit slowly. But I have bought it the bigger iPad charger. The iPad was an eBay purchase and came with its original box and lead only. Am now buying it some Toys…
I tried a very old Card Reader, but my Windows 11 PC won’t read an SD Card from the D7000 - and the iPad cannot see it. Its very old… And probably isn’t recognised by Windows 11 and/or it cannot read modern SD cards.
I will start looking for an Apple SD Card reader…!!
My Apple SD Card Reader arrived today - Apple A1595 (SD Card to Lightning).
Works…
Effectively, I ‘wasted’ the money I spent on the A1619 USB Camera Adaptor - which works with a USB stick - but will not ‘play’ with my Nikon D7000. Whereas the SD Card Reader will reads the D7000’s cards directly, no prob - with no additional power needed.
