Could someone kindly suggest cheap bookshelf speakers to connect to an ald but good Arcam alpha3 ?
Thanks in advance
Something s bit lively like monitor audio or russel k should work well
thanks. what do you think about B&W 607 ?
When I had the Arcam Alpha 10 bought new in 1997, I used B&W CDM1 SE with it. Glorious sound.
A nice pair of Goodman Maxim 2s. Shouldn’t cost you more than around £25-50 the pair. Spend the rest on some really solid stands (assuming by “bookshelf” you aren’t meaning to put the speakers there) and some decent but not too costly speaker cable.
Goo idea Richard. Unfortunately it seems impossible to find it in Italy
