- Yes
- No
- Not anymore
0 voters
0 voters
@Simon-in-Suffolk do you know if running roon core on a laptop, is it beneficial to have it connected to switch via Ethernet, or is it ok to stick the laptop in another room and it just using WiFi?
The reason I ask is unless I am missing something, the fan on the laptop is a distraction in the same listening room unless there is a way to stop it?
And lastly if I remember correctly when I tried the roon trial if the screen sleeps, roon stops.
So ultimately I donât want a noisy bright computer sitting in the same room as I am listening (Cisco 2960 next to Hifi). Any suggestions other than using a different type of core?
Many thanks
I run the Roon core on my home network, itâs well away from my audio equipment in another part of my house. Obviously the advantage of using Ethernet is it doesnât need to be anywhere near your streamer.
In my experience running Roon on OSX, it carries on regardless of screen sleeping or not ⌠in fact works really well just sitting there in the background, so I save running costs by not having to run another server âŚI use an iMac
I tried it (twice) and didnât like it, first time 3 years ago a very strong dislike, the second a year ago some of the worst things had changed, and other things I particularly disliked I found could be switched off, but I was left with something that brought no benefit compared to my present library/rendering software (Audirvana), but costs a lot more.
I liked its user interface but in the three trials I have had the SQ could not quite match that of others I have used.
Its astoundingly good software when you have multiple end points. I have multiple end points and think 100 quid a year is trival for what it brings.
recently updates have made roon radio much better, I am getting rich seams of great music coming through.
If you have one hifi, one audio point, then its probably not worth it.
I am just having a go at the trial for the second time around. I only use Qobuz and only hold about 4 hires albums on a connected SSD.
How do you work the roon radio, I canât see it. Maybe thatâs because it hasnât built up enough information on me yet?
I run Roon Core on a MacBook Pro, and I can confirm that it the screen doesnât need to be lit up for it to work. I can control it on an iOS device while the laptop is asleep. I donât know if the same would apply on a Windows laptop.
I have a network connection to the MacBook, but if I donât bother plugging it in, it still works surprisingly well over WiFi. If I listen carefully, I can possibly persuade myself that WiFi doesnât sound as good, but any differences are marginal.
Pick a track and click it a pop up box comes up choose rood radio.
It think its using deepo learning or what evs so might be building up a profile for you.
That being said, when ever I play YES, it always please either EL&P or bloody Genesis after. I hate Genesis, and every time it plays I skip and tell it I dont like this track, but it never, ever learns.
Roon radio is designed to continue to play music in the same vein as your current playlist. So for example, play one track by blur and roon radio will keep going with oasis, pulp ⌠playing from wherever it can source the music, either local or qobuz.
When I trialled a year ago, it was âonâ by default - and took me unawares when upon reaching the end of an album I had selected to play from my store, it kicked in, suddenly playing a random track from the middle of another album in my collection. It was awful, completely jarring and out of context! That was the first I knew of the âradioâ function, but it was a few days before I learnt that was what it was and how to turn it off.
Roon radio has been improved in the latest release, and in my experience plays music more in keeping ie less random.
Iâm pretty sure that I would still use Roon even if I had only one âend pointâ, but in my case I have 4, and Roon makes integrating each of these systems so much easier and makes operating each of them so much more pleasurable.
This is a schematic of my systems and home network:
My bedroom system (Zone 3 in the diagram) suffered from an appalling front end app for my Marantz streamer. Roon has completely resolved that issue and allows me to stream files of any format to any of my end-points. My Brooklyn DAC+ supports MQA and DSD. The rest of my systems do not. As well as having a fantastic front end app for each of my systems now, I donât have to worry about that. I just select a file to play - any file in any format. If the system I am listening to doesnât support the format, Roon detects this and converts the file on the fly to the highest quality PCM file that the device in question does support, and of course it also carries out the first MQA unfold to each of my 3 systems that do not support MQA.
Quite simply, completely seamless and a joy to use.
Not for me at all - it is information for informationâs sake. Tried it twice and to me, it just gets in the way. I prefer the Alexa/Siri approach - you just say âPlay Dark Side of the Moonâ and it plays
Very good album
Unless it plays complete albums not isolated tracks, and happens to correctly judge my mood at the end of whatever has been playing, I am likely to find it irritating at best. Picking something of the same genre, or style, or even artist, doesnât work because my mood may be changed by what I have just played to want something different - or not.
That has just depressed me.
Iâve been a fan of Medicine Head ever since âPictures in the Skyâ. I have 5 of their albums in my Roon Library as well as a few on vinyl. I thought Iâd give the album a play since itâs not an album I have heard, but to my dismay itâs not available in Tidal.
Of course it couldnât be as good as the PF version, but Iâm sure it would be a great version in itâs own right.
Dunno, thatâs the one thing I am enjoying, find someone you like then you get all the album cover/booklet information plus loads about the artist and all sorts.
But a bit jarring if it plays the other Dark Side of the Moon, rather tgan the one youâre expecting?..
And Siri (or Alexa) should ask: âWhatâs the magic word?â if you fail to be polite and say âpleaseâ!
What other Dark Side of the Moon?
Hey Siri play Nirvana
Of course I could have used the album title âHey Siri Play The Existence of Chance Is Everything and Nothing While the Greatest Achievement Is the Living of Life, and so Say ALL OF USâ
And then there is my favourite Chumbawamba album âHey Siri please play The Boy Bands Have Won, and All the Copyists and the Tribute Bands and the TV Talent Show Producers Have Won, If We Allow Our Culture to Be Shaped by Mimicry, Whether from Lack of Ideas or from Exaggerated Respect. You Should Never Try to Freeze Culture. What You Can Do Is Recycle That Culture. Take Your Older Brotherâs Hand-Me-Down Jacket and Re-Style It, Re-Fashion It to the Point Where It Becomes Your Own. But Donât Just Regurgitate Creative History, or Hold Art and Music and Literature as Fixed, Untouchable and Kept Under Glass. The People Who Try to âGuardâ Any Particular Form of Music Are, Like the Copyists and Manufactured Bands, Doing It the Worst Disservice, Because the Only Thing That You Can Do to Music That Will Damage It Is Not Change It, Not Make It Your Own. Because Then It Dies, Then Itâs Over, Then Itâs Done, and the Boy Bands Have Won.â
Does Roon now give you the genuine album booklet? When I tried it had some rubbish from a pretty clueless reviewer (I think Allmusic, which is almost as bad as Rolling Stone. Do these people even listen to the album?) - I found it quite annoying. Of course the worst ever reviewer was Jeff Dreadnaught (please tap or click)
If Roon has axed reviews in favour of the booklets that come with the CDs or LPs then that is very good. And it is good that you can disable the suggestions.
I usually get JRiver Panel to display the lyrics of the currently playing song.
Yes I understand some folk love Roon and like to know who played sax on Gerry Raffertyâs Baker Street.
