I have a pair of Arivas that are 15+ years old. Is anyone familiar with the crossovers? Do they have electrolytic capacitors or any other components that mat need replacing?
If so can anyone offer advice on how to remove the drivers without damaging them, or the cabinets, they appear to be firmly located.
Hi Philip, welcome to the forum, i know @JimDog asked the same question last year and it was said they are not a normal service item unless you feel they sound awful. Perhaps jimdog can update you in what he eventually did?
Yes I was wondering if the crossovers included electrolytic capacitors as I am not enjoying the sound of the Arivas as much lately. Maybe it is time to experiment with some changes. I will look at the remainder of the system first…
Meantime I will check the plinths and contact Naim.
