Artists/Albums not showing in Naim App from Asset
I’m trying out Asset on my Mac Mini, installed a couple of days ago, folders seemed to scan OK, but Asset did not find by my Muso for some time, then everything disappeared, now it’s back showing on the app, but only a handful of albums/artists are found.
I did think they may be ones originally ripped using iTunes/Music, but I’m not sure. However, they’re not appearing on the Naim app. Any clues as to how to resolve this please? I’ve also asked on the Asset forum :slight_smile:
Thank you
Doubt it is an Asset issue. Can Asset be seen on your network? Have you got other ways to see Asset such as a smart a TV on your network?
Apple or Android to contol the Muso?
I don’t have any other way of seeing Asset that I know of - very new to this. It’s the same issue on both iPhone and an Android tablet
I see you have posted the question on the dBpoweramp forum, that has to be the best way to find the answer.
The Asset configuration settings select what and how is sent over DLNA/UPnP, this may be affected by something in the Mac programming, but the Naim app can/will only show what is sent.
What are you trying to achieve my using Asset and the Muso beyond the obvious? If you have a simple home network and just want to play ripped cds, then maybe a USB stick into the Muso may be a simpler way?
You’d get a very basic folder view using the USB input on a Muso. Not a great way to browse more than a handful of albums.
