Asset & file types
Hi
The music files on my NAS are arranged in bitrate order eg 16 bit 44.1, 24bit, 24/ 192.
Since some artist/ titles are duplicated can Asset maintain these groups?
Dont really want to rename files if i can avoid it.
Thought it might be nice to compare different bit rates on same recordings.
I will be archiving all my vinyl soon and want to keep my albums on a separate file
Thanks in anticipation
In the Asset menu go to Additional then chose either bits or frequency. Can sort by either or both.
Didn’t know that, just goes to show I should poke around the asset menu some. I’ve always added the resolution to the album title to keep track of hires albums.
