I have recently installed Asset (v7.2) onto a QNAP NAS and all went well. The Naim app picked up the server and is displaying everything as expected.
The irratation is that if I (for example) selct Albums from the main screen, it takes me to a page with an alphabet and a asterisk (all artists). When I select the asterisk I then get all the Album thumbnails that I am after. Similar when I select Artist - I first have to go through the A,B,C screen to get to where I want to be. Is there a setting within asset that allows me to bypass the alphabet screen and go stright from Album to Thumbnail?
You need to edit your browse tree settings … Asset’s default browse tree is very comprehensive, & I don’t know anyone who actually uses it as supplied.
The reason you see the Alphabet & Asterisk screen is because the browse tree for whatever branch you are viewing has A to Z enabled.
What & how you want to set it is a personal preferences thing, but once started on your own preferences its easy enough, although expect to go around the houses a few times.
This is my browse tree, not saying to copy it, but it shows you some clues as to what can be done.
