If you haven’t spotted it, there’s a new Asset UPnP release available - R6.3.
Changes from R6.2 include
Made transcoded MP3 bitrate configurable via webconfig (Linux)
Made possible to edit database fields through configuration dialogs/pages
Made device ID generation consistent with Windows version of Asset, should fix certain devices being unable to show more than one Asset instance
Mac OS Mojave Dark Mode compatible[/b]
Improved behavior of playlists referencing external storage on Mac OS.
Fixed missing Composer info when browsing.
Added automatic recovery from database file corruption; should address problems with Asset completely failing to see music for some users.
Added Mac OS Catalina compatible code signing.
Existing users update for free, look out for the “Existing Registered users update with Registration Retrieval” at the bottom of the Buy page
Thanks for the heads-up. With no automatic notifications of new releases, it is handy to have others keeping an eye on it. Downloaded and installed the versions for QNAP and synology without any issues.
Can’t help with QNAP, Synology is touch the install button & browse to wherever the software package is. In my case I download it into a Windows folder & install it from there
All done! I’ve noticed that new albums no longer show up virtually instantly in the Naim app, and require a rescan. I do hope it’s just an initial glitch.
I did not have that problem, it all showed up as before, instantly as you said.
Maybe your’s went into a scan straight after your update, who knows.
I don’t have the config set to do a regular rescan, the box is not ticked. I just run a check for changes when I load a new album,
I think I’ll raise it on the asset forum, if I can remember my password. I have the asset config screen directly accessible from my iPad so it’s not a big deal, but I’d rather it be as it was.
I won’t do that then! I see you’ve posted on the dBpoweramp forum on the thread I started, so we each know we are not alone. Let’s see what Mr Spoon has to say. Hopefully it can be fixed.
It’ll be a simple fix, some code has probably been commented out during the development of the new release and not been put back.
Mr Spoon is usually very prompt in responding and others may post too now they know it’s not just them.
@hungryhalibut@Guinnless I’ve had a fiddle around with my Synology & it seems I might have a problem after all. Can you confirm its the same problem as you have
When I open any of the browse paths - e.g.Album/Artist Album - it shows all the album cover art listed instantly.
I select an album it shows straightaway on the iPad with cover art & all the tracks.
When I touch load & play, it takes a few seconds to load, play & to show on the now playing screen. Its not a problem other than its not loading & playing instantly as it did before - is this the same as you guys.
