I don’t understand why the bottom and top shelves are double width and the middle ones are divided. All those vibrations moving between the two stacks. I’d be inclined to take a saw to it!
As to Bluesfan’s suggestion yes, it’s best to have the power supplies in the right. When I had a 552 and 300 the cabling wouldn’t reach if it was the other way around.
I’ve yet to try the P8 without the glass on the Fraim.
The guy from Rega also said in his opinion they sound better sitting directly on the wood and not on the glass.
Also did you buy this yet?
Yep got it, the box set like pauls, only it was up for £120, i also got 10% off it.
Just need my aura to turn up do i can play it, but have it downloaded so i can revisit keith dont go.
