For some time now I have updated my system by inserting the Matrix 2 power strip (using a standard Naim cable) and a digital cable + analogue cable both Chord Epic.
In the future (funds and time to choose and test permitting) I will consider an upgrade of the speakers if I deem it necessary.
At the moment, however, I would like to know what I could consider as a (small but good) upgrade from the following options:
- upgrade of NACA5 (and if so, stay on Chord EpicX for homogeneous system wiring even if a Naim Snaic is involved, or just focus on the Nap 200DR -> Harbeth link?);
- upgrade of the standard power cable of the Nap 200DR (but I donāt intend to invest so much in a Powerline);
- upgrade of the standard Naim power cable that I have on the Matrix2 power strip (non-Naim hifi products are also connected to the power strip).
Thank you in advance for any suggestions, indications or shared experiences.
