Hmm what errors? Mine just works flawlessly must be a setting. Are you using ip address or the name of the server? I have found that sometimes it won’t connect using the name and stick with IP addresses.
I use the IP address. Use Guest and Guest for login and password.
It consistently sends back the error:
Warning 2020/07/21 08:43:11 System 127.0.0.1 Hybrid Backup Sync Custom Job Event [Hybrid Backup Sync] Finished Sync job “Active Sync 1” with errors. Failed to copy all data and attributes.
Roon Nuc is mounted:
Something seems wrong as the HBS 3 app can’t retrieve the directory from the Nucleus though:
