ATC SCM20ASLs – expected more…
Auditioned some active ATC SCM20ASLs for a few days last week – something I’d wanted to try for a while. I’m very happy with my current Spendor D7.2 speakers, but the more you read this forum, the more you want to experiment/upgrade!! Current system is 2 boxes: NSC222 & NAP250. Actives would reduce the box count to one!
The verdict: neutral. They were no better than my current speakers/amp, with much weaker bass and a less pleasing sound overall. Also noticed I needed several points higher on the volume knob for the same level of sound (speaker sensitivity maybe?). Happy to have scratched the itch but I’ll be sticking with what I have.
Given the reviews and loyal following for active ATCs, I expected more. However, in my room, they were not an improvement over my current set-up. Maybe it wasn’t a fair comparison, bearing in mind the cost differential of approx. £5k. As the adage goes, always try in your own home before buying/changing components…
Yeah similar story here with active 20’s a couple of years ago.
My speakers are ProAc D20R with Naim 200 series which provided a more natural, engaging and fuller frequency range - probably down to my personal taste.
@Cluffy I really like my D7.2 as well. They work with my 332/333/NC250. They are fairly sensitive and easy to drive. I have no desire to change anything.
You have a wonderful system, @Jaybar … enjoy the music :+1:
@Cluffy The transition to just listening from frequent upgrading is a new thing for me. One of the upgrades in SQ has been moving to instant on and keeping the system on 24/7.
Choosing a speaker can be difficult. Our issue wax height. We have a NYC skyline view and we did not want our speakers to interfere. Many were too tall.
Bear in mind firstly that people”s tastes in speakers differ, and secondly general active preference is only relative to the same speaker passive. The 20’s spec tells you its bass doesn’t go low. As for volume control setting, it is immaterial, unless on the one hand the highest doesn’t go high enough, or on the other where there may be insufficient knob movement for comfortable control- seemingly common with Naim systems.
If I just breath too hard in the general direction of my NAC72, it goes alarmingly loud… :rofl:
Always treat unverified comments online with a pinch of salt!!
Were the ATCs well run in? There’s every possibility that they would sound relatively poor, especially in the lower frequencies, if they weren’t. I’ve known even well run in demo speakers to need quite a few days of use before they sound right if they haven’t been in regular use by the dealer.
Speakers like the ATC SCM20 are not everyones cup of tea. I use passive 20’s in a fairly small room and love them. They work in my envoronment and I find them increadibly transparent and realistic, but there are compromises. They are brutally honest - they do not add warmth and expose harsh recordings for what they are. The bass does not go very low, and many people add subs for this reason, but in my envoronment, and my taste in music, it’s enough. I’m not surprised that they probably sound cold and lacking in bass extension if you are used to a ported froorstander like the D7.2. I wonder if the SCM40A would be better suited if you want to experiment further.
Hi @Cluffy Speaker preference, like all hifi in fact, is very subjective so I’m not at all surprised at your findings. Spendor and ATC are chalk and cheese so being used to and enjoying the former, it was near inevitable you’d find the sound of ATCS less pleasing at least at first. I come from the other direction and prize neutrality as do ATC so find the sound of those Spendors I’ve heard to sound rather coloured, too much so for my taste. Chacon a son goût as FR would no doubt say.
A few other points. I’m intrigued you chose active 20s to audition as 40s and 50s go lower and the former, being in the “entry” series is a little more forgiving and has slightly less of the “studio monitor” sound. Secondly, I find that ATCs need to be played at closer to a realistic volume than some speakers to really show what they’re capable of — it’s that studio monitor heritage again. Finally, ATCs are very revealing of sources and preamps. I’d at least want a power supply on the 222, but 300 series gear would be a better match. IMO of course.
So interesting experiment and continue to enjoy your music.
Roger
I take it you had a tinker, sorry carefully adjusted, the bass shelf and trim controls?
Although indeed when I auditioned the active 20’s against my 505’s a few months ago I too could find no reason to swap my NC250/505’s for active 20’s…….. I felt they just came across as a little ‘thin’.
But others here are delighted so I put it down to YMMV :person_shrugging:.
ATB, J
If you really want to reduce the box count to one and go active, based on the system you have, 20s wouldn’t be my first choice, 50s maybe but you are taking a leap in sound signature even there. 20s have a place but I can imagine a 222/NAP250 and a decent pair of modern floorstanders in the right room would be hard to beat.
I have Kudos Titan 606s with mine :grinning_face:.
I wouldn’t dream of 20s without subs. Actually I wouldn’t dream of 20s at all. 40s (with that sublime mid driver) is the lowest I’d consider…again needing subs. Though at least one member on here uses 20s with subs.
Yep, I’m one of those. :grin:
Hey there, there are plenty of good speakers out there, and the ATC SCM20 ASLs are among them.
Actually, I think they’re very good, and after months of fine-tuning (positioning relative to the room’s ‘zero’ point and so on, as well as choosing the right stands), I’m getting over the shock of having sold my beloved Harbeth M40.2 Anniversary and forgetting that lovely, sculpted and articulate bass that the ATC SCM40A gave me – partly due to the height of the drivers relative to the floor, and of course thanks to that marvellous midrange driver they’re fitted with.
I’ve also owned the passive version of the SCM20, and my opinion remains the same: they require a great deal of care in positioning, which will improve their response and mitigate the sense of harshness that some may have perceived.
My set-up now also includes the ATC C4 mkII, set to a 50 Hz crossover.
Why didn’t you keep the 40A’s? I confirm for the bass… (the rest is excellent too!)
I bought the Harbeth M40.2 Anniversary speakers, taking advantage of a bargain, and kept both pairs for a few months. Although the choice was not so easy, the natural sound of vocals and wind instruments – perhaps due to the Harbeth’s greater extension or, in any case, its capacity for finesse and airiness – was evident. In the lower-midrange, however, the ATC Scm40A speakers left me with a very favourable impression.
Before I started seeing results from the integration between SCM 20ASL and C4, I’d thought about bringing them back, as they fitted in very well with my room. It’s been a few years now, but I wouldn’t go back.
I dealer-demoed ATC 20, 40 & 50 last year fronted by both Atom HE and NSC222. (ATC Actives Demo - Oh dear …)
I was disappointed with the 20s and 40s particularly in respect of bass response. Plenty of forumites love them though; the 20s with and without subs. Room compatibility seems to be very important as you would expect.
I felt the 50s were in a different league (so they should be given the price), I bought them with a 222 and the combination has not disappointed.
The ATC SCM 50s are just great speakers active or passive. I use mine with a NSC222/NPX300 and a NAP250.
