Atom he Headphone Button
Hello, I have a Naim Atom HE. I currently use the 6.5mm headphone jack on the front panel to listen to headphones. I want to add active speakers and plug them into the RCA line output on the back. Can pressing the Headphone Button on the front panel switch between headphone and speaker output? Currently, I only plug in the 6.5mm headphone jack and press the Headphone Button but nothing happens.
It is working correctly. Plugging in your headphones to the 6.5mm jack will switch off the RCA (and balanced) outputs to the speakers. The rear headphone outlet has no such ability, if you are using that, you need to manually switch between the speaker outputs and the headphone outputs.
Thank you, when I use the front 6.5 port and RCA port to connect the speakers, I can only plug in the 6.5 headphone port every time.
