Some advice for a new headphone convert please. I take delivery shortly of an Atom HE which will be connected to my Nap 250 DR on my Fraim
Rack. My seating position is around 3-3.5 metres away and I will be using Focal Celestee or Clear MG headphones.
I reckon I need a 4m extension cable. Should I go for a balanced cable, given the length I need, or stay with standard connection and what makes of cable do you recommend please?
I use a Mark Grant extension cable. Trilogy 931 amp to Focal clear.
Heavy, thick enough to supply power to Coventry. Never found it lacking.
Speak to Mark about balanced. Very helpful guy.
I tend to use his wares over and above known brands.
Grado also make an extension.
Many thanks - I had forgotten about Mark Grant Cables although I recall they have a good reputation for quality at an affordable price. I will contact him for advice
Got my 4m balanced cable from custom cans for my Clear Pros. The Focal 5m coiled cable was way too heavy. But I expect well built. Try custom cans. Great sound and colours too.
Thanks for all the ideas and I will pursue although I think Custom Cans or Mark Grant may be the preferred cables as I expect Focal will be a lot dearer
