I’m having a problem on my Atom HE where Tidal Connect stops playing after a while.
Trying to re-connect to Tidal Connect it says ”chromecast” and then that option disappears.
The only way to fix it is to do a hard re-boot of Atom He, after that it’s possible to connect again.
Anyone else experienced this?
Bumping this as I’m having the same issue - although “Chromecast” option remains…
Been running wired instead of wi-fi for a while and haven’t had the problem since the change. Having mixed feelings: great if there’s a ”work-around” but it really sucks not being able to use wireless!
