On my Atom home screen, I can see a Spotify icon and easily switch between inputs. Is it possible to change Spotify to be Qobuz and then get it to play from where you left off? Or do you always need to reach for the app?
I assume favourites are for radio only so I won’t even ask about adding in albums or playlists.
Nope to the icon you need to use the App. Favourites can be radio stations or if your using Tidal or Qobuz then they add it to your Qobuz or Tidal favourites and sync back to the respected service and will show up in the My Albums sections.
