How do I connect my sub to my atom ? Using an RCA from my sub from the lfe can I connect to the pre out of the atom.
You can use the RCA phono pre-out, however, don’t connect into an LFE input - that will be expecting a pre-bandwidth limited low frequency effect channel input from an AV processor. You should use a pre level input that will allow you to apply frequency filtering and level control, as well as hopefully some form of phase control. What subwoofer are you using here?
