Hi!
I’ve had issues with the volume resetting to the previous value on the last two firmwares. Using the remote, increasing or decreasing volume does change it but it resets to the value I had before the change right away. Same if I use the app to change it. I managed to set the volume from within spotify using the side buttons on the iphone without it being reset… Anyone else experienced this?
