Thank you for your feedback. I have since checked with Qobuz’s help centre. I read there that playlists are not automatically searchable by others, even if they are marked as “public”. Instead, I have to create a separate link and send it.
This seems to be new to me. A few years ago, I shared the title of my playlist here in the forum, and others were able to find and play it on Qobuz without any problems by entering the title. I have added the link at the top of this post. Perhaps it will work now…
Thank you very much @Wilfried, very kind of you. Interesting what you found in Qobuz help center, I did not expect that. By the way your link works (finally!), I can open it in the web browser. Later I’ll try it with Qobuz desktop too, I’m pretty confident it’ll work. I’m curious to explore your list. Again, thanks!
Link worked for me after failed searching earlier today, thanks. Will take a listen later.
Playlist finally added with success ![]()
@Blacknote @DrDavid I’m glad it worked out in the end. Enjoy!
