im having an issue when im playing audio from tidal subscription in that it usually stops after about 30 mins or so , and after it stops playing it locks up whichever device i am using at the time and have to switch it off to find it agin in the Naim App, also when i get to reconnect , i have to then switch off or select radio on any other device if i want to steam to them using the party mode .
ive set tidal to high and not hifi in the Naim App as i had read this somewhere … i can steam from my local storage device (synology NAS), using HQ FLAC with no issues for hours , i dont have any other music subs to test with
My devices are Muso qb x2 and Muso all first gen
ive got 1 Muso QB connect directly at the router , 1 over Wifi and one connected using powerline adapters
i know the powerline adapters can cause overheads , but they are running at over 150mbs and it happens with the unit that is directly connected to the router through ethernet
should have mentioned , no problems playing directly to any device using Bluetooth using tidal or Spotify (Free), plays seamlessly until you stop it …so looks as if its only with the naim app and tidal… which is a bummer as was liking the idea of centralizing it all
paddi
just a quick update on some testing , changed all the settings in the tidal app for all the devices i have to High , i think i may have had one of the devices set differently in the app… so after some more testing it seems that it will only drop out when im using multiroom feature (which was one of the main reasons for purchase) while using Tidal , i logged a call with NAIM support about a week ago, but looks like they are busy so have added a gentle reminder … so hopefully hear something back soon…paddi
so , i signed up for a free trial of spotify for testing (3 months free using paypal) , and it plays seamlessly across all 3 devices using multi-room for over 7 hours ( i had to go to bed), although i’m not sure the spotify and Tidal integration with the naim app are the same .but looks like spotify might be the best option for me … still waiting on support to come back to me
