FWIW I used to have the Wireworld Matrix 2 (UK) in my system. Once I found a way to plug critical components directly into the wall outlet, I then realised the WW Matrix 2 is a severe compromise to the system. Similarly, if anyone is still using the WW Matrix 2 or similar budget power strips, I would recommend to replace it with something like this Niagara (although I haven’t tried it myself )
which network conditioner, which model (it can be found on the European market) have you installed to have these good results?
Assuming this is a generic question Francesco, in my case that is the Pink Faun LAN isolator.
