I finally got Audirvana working on my old laptop and iPad.
It sounds quite different and in many ways better - I just stream Tidal.
I suppose this is because it transcodes Flac to wav?
But the music gets a few occasional gaps where it stops playing for a couple of seconds. And sometimes just stops playing altogether mid track or during an LP. And sometimes jumps to a different track.
Are these glitches common? Can they be solved?
My laptop only has 4MB RAM. Audirvana recommend 8MB, but say that 4MB should work. Is that the problem?
Should I get a Mac Mini or other headless computer to run it?
If so, which ones are good?
My laptop canāt remain on and open 24 hours, and itās extremely Electrically noisy. Plus its HDD makes an audible whirring sound.
Jim
It could literally be 101 different things. Have you turned on task manager to watch what the CPU and memory are doing during these dropouts? Ditto for the network, especially if wifi.
4GiB seems okay to me. Mine manages fine and handles 4K video streaming. You might have other services in the background interfering too.
There are literally dozens of assorted Microsoft slushware programs running in the background - most of which I either havenāt heard of or never use.
The ones that seemed certainly non-essential for running the PC I switched off, but that was only 3 or 4 things out of about 50.
So it could well be all the stuff Microsoft uses to bung up PCs to force us to buy new PCs thatās eating most of the processing power.
The 8GiB recommendation is extremely conservative. My box with 4GIB always has 1.5 GiB free. Audirvana uses up maybe a few hundred MiB at most. If you turn off unnecessary services and remove software you donāt use, memory limits are unlike to be an issue.
I use a new, but low ish spec Lenovo mini PC. Out of the box it was a bit clunky but I turned off all Windows features I donāt need, Uninstalled nearly everything, and turned off services that arenāt essential. Purring like a kitten (well not literally, itās fanless).
Iāve had more Asus stuff than I can remember and theyāve also been fantastic. Iād definitely look at the isdue in a bit of detail. Of course if you are short on patience and have the money, buying a new device will probably fix the issue too. Iāve certainly had other non computer related issue where I thought āmy time and blood pressure are more valuableā and happily thrown money at the problem to make it go away. No judgement.
Iām only thinking of perhaps throwing Ā£200 to get a headless several year old Mac Mini - as Iāve heard they are electrically less noisy than most PCs, so should give better SQ (?) - and it would be less obtrusive.
I know a lot of computer audiophiles use them as stores/servers.
but then a quick look online suggests that one can buy a new Lenovo ThinkCenter M710q Mini PC, Intel Core i3-7100T 8GB DDR4 128GB SSD Win10 for Ā£250ā¦!
I take it youāre using Audirvana as a DNLA/UPnP server to stream across the network to your player? I havenāt used in that mode, only using for its excellent performance as a renderer feeding DAC direct (via USB). However when Audirvana first added DNLA/UPnP server capability to Audirvana I recall people had problems using it with Naim streamers, possibly because one or the other didnāt follow the universal protocol (my interpretation). Maybe someone who has used Audirvana in that mode and has overcome the problems can help.
Using it as a renderer, with the Mac Mini it is on as a store, i set it up on a ālate 2012ā model MM, which was the last I believe that had non-soldered RAM. It has a Core i5/2.5GHz processor, and I installed 16GB RAM and a pair of 1TB SSDs. The RAM may be overkill, but as Audirvana loads each entire āsongā into RAM before playing it guarantees even whole-album hi res tracks can be loaded without without trouble. I stopped at IOS El Capitan 10.11.6, because that is the last that allowed Audirvana to be run in Direct mode (at least, without a patch to IOS first. I use it fully optimised (Direct Mode - Integer Mode 1, dedicated usb port, sysopt etc), and as well as silent the MM is headless, with no screen or keyboard - if I need to access it. as opposed to just using Audirvanaās control app on a phone or tablet, I use VNC (free).
It works very well in my usage, with one limitation: poor handling of files tgat have poor, missing or inconsistent metadata, which to me is a pain and one day will prompt me to move on. If your metadata is good - or just stream from Tidal or Qobuz etc, that shouldnāt be an issue.
If it really is impossible to get a stable Tidal feed to a 272 from Audirvana then I may just have to wait a while longer to see whether a 372 finally emerges.
I use BubbleUpnP and can stream Qobuz to Naim devices perfectly. BubbleUpnP also supports Tidal and I would have expected it to work OK.
What happened when you tried?
I use Audirvana in upnp mode to a Muso 1 and previously an NDX. Iāve never experienced any notable problems. Iāve had Audirvana running on a Windows laptop for the past 2 years.
