Hi
I would now like to go for an AV update.
I have now connected my older but very fine onkyo av receiver via pre out to the 52 and use the integrated onkyo amps for surround and center.
I would like to buy a new av controller (not sure which one, but I will find one like anthem or lexicon) and use for the center and surround a Naim nap 175.
Is this possible:
connecting the rca pre-output for center to nap 175 directly
connecting the rca pre-output for surround left right to nap 175 directly
Do I need specific cables - like for center who only needs one rca plug?
Thanks for a word
Best regards and stay all safe in 2022!
Yes, what you suggest would work. I used a similar setup, albeit with a couple of Naim power amps to do the centre and rears. You’ll need a 2xRCA to DIN4 cable and a single RCA to DIN4 cable, wired as per the image below from the manual
Thanks again.
Actually I found 2 cables in my old boxes. I bought them (one cheaper for testing and one chord chrysalis) for adding a sub which never worked. Where in the box for 20 years.
Both 4 din to rca (ok - wrong direction).
But it worked and now power amplification is fully Naim :o). Sounds good.
But I do really want to have final cables
What should I do. Any advice is welcome:
buy 2x chord Clearway (stereo cable for mono only using one channel)
ask my dealer to use my old chord cable (chrysalis is the same as lavender if I remember) and cut 2 pieces out of it … and build me the cables. The sub cable from chord is 9 meter long.
Will the latter be an option or is the cable too old?
Sounds like a plan. It’s decent cable so you may as well finally get some use out of it. Once the other two cables have been made, you could also get the dealer to re-terminate the length of cable that’s left over and sell that on.
Hi
I have too much time, so I am thinking about buying an av controller.
To be honest…
I am a bit lost.
I like to have a good one matching to Naim (52/135 for front and 175 for the rest - only 5.1 with linn Sizmik sub)
A had looked up:
marantz 7706 - no Dirac but maybe easier to handle
And the dirac ones… I am a little afraid that I will go lost in the dirac universe. I do not understand a bit of the stuff from the videos mentioning the manual corrections that should be done…
And all dirac processors do have some hiccups.
These are
anthem avm 40
lexicon Mc 10
arcam 860v
nad…
Any advices from your side.
I do only need 5.1 and had sound. No atmos necessary but I really would like to go for fine and detailed sound.
