Hi All,
I love my Avid set up, but think it has more to give. I’m only using a Chord Clearway RCA to RCA from the phono to preamp at the moment.
Option one is to just upgrade the RCA cable. Perhaps something in the Nordose range, or the Avid SCT interconnect. I’m looking for neutral but more detail.
Option two is to go balanced (the Avid Pellere is balanced). I guess I need to change the tonearm cable to XLR output. From what I’ve read though, all I can do with the NAC282 is get an XLR to DIN cable, so it will be balanced until it enters the preamp.
Is going “part balanced” worth it? It’s only a 1m cable? This route would cost me two cables? More money could be spent on a better option one cable?
Any experience on having a balanced phono but not preamp, and what you’re doing, is all greatly appreciated.
Thanks,
Rich
Hi Richard,
I would suggest trying an RCA-to-DIN cable between your Avid Pellere and NAC 282 before spending a lot of money on expensive RCA interconnects.
In my own Naim system, switching from a high-quality RCA connection to a relatively inexpensive DIN connection actually improved the sound.
One reason is that Naim has paid particular attention to signal grounding and the way its equipment handles ground connections. The signal DIN Naim connection has 3 pins: GND, CH1, CH2.
However, it’s important to remember that Naim’s DIN connections are not balanced, even though they use DIN connectors.
Since your NAC 282 has unbalanced inputs, I don’t think using the Pellere’s balanced XLR outputs via an XLR-to-DIN cable would necessarily bring any advantage over a properly wired RCA-to-DIN connection.
Personally, I’d try that option first before investing in more expensive cables.
Best
Lionel
Thank you for taking the time @lionel.clement
