I have recently bought a pair of brand new 804 d4 from dealer with a very good price. I’m now still using my Naim 252 + 300dr to drive them but found that the mid and low of 804 are much worse than what I expected when playing nearly all kinds of music. I used to use this Naim combo to drive my 3-year-old Pmc fact.8 signature and even 13-year-old AP Virgo25 and they all work very fine in my place.
I thought that phenomenon might be ascribed to the insufficient run-in time. I have been running the new speakers for around 50 hours with different kind of music. How much time more should be used to run in B&W speakers?
Whilst I have never bought B&W speakers, from my understanding generally with speakers I would expect running in to be achieved by 50 hours playing, provided it is with sufficient volume to have good flexing of the bass cones. If played quietly it might take a fair bit longer, very loud with strong bass content could well take less.
Did you audition the speakers first? If not it might simply be that tgey’re not to your taste.
I don’t know the B&Ws but I agree with @Innocent_Bystander that running in will be heped by playing music with strong bass content loud. Recently having purchased new speakers myself I found that they took a good few weeks to run in properly and the sound changed very significantly during that time. It started off being comparatively shut in and dynamically constrained with limited bass. I wasn’t concerned because I’ve experienced it before with new speakers so knew what to expect. Now they sound excellent. I would hang on in there and give them longer to show their true colours. The only caveat to that is that I would say if you really dislike the sound you are getting now then I don’t think that will change with running in. It gets a lot better IME, but the fundamental character doesn’t change.
I could only use softer music when running them at night. I do agree that playing louder music with strong bass advantage of running in the speakers.
I used to have BMW804D2, but they were not bought brand-new. The ex-user we are using them in his private theatre, mainly for watching movies. When I started to own them they were in excellent condition. Therefore, I would supposed that it should be due to the r
unning problem.
how much time should be needed to run them in if I would expect they are in perfect listening condition?
It obviously depends on how much you use them, volume and type of music. From my own experience I would expect them to continue to improve over several weeks, but probably the bulk of the improvement happens within the first few days or so. After that it’s just the icing on the cake, but still very worthwhile.
If you bought them used, then they would be already running! If they were brand-new then 50 hours is the normal sort of guideline. But of course if you’re playing them only quietly might take quite a bit longer.
A trick I have heard of people doing is putting the two speakers facing each other right up against each other – actually touching if nothing protrudes including the bass cones on maximum forward extension – reverse the connections on one speaker so that it is out of phase with the othe, then play music at a high volume control setting. The cones moving in opposite directions right significantly reduce loudness in the room. You could do that during the day and even leave it running when you go to work if you have a streaming system, to clock up the hours rapidly.
What do you mean by worse? Muffled and lacking in energy? I’ve owned B&W 702 signatures on my SN1 and they took very long to run in. I did not count the hours but it was many weeks of daily listening. Two things that made a huge difference were 1) positioning: just a few centimeters had an enormous impact on soundstage and separation and 2) adding Isoacoustics Gaia feet: low end transformed from mediocre to the most controlled and realistic I have ever had. I’ve been a fierce promoter ever since
I always understood that running in is best done at normal levels, I’d say give it some time: your setup should sound spectacular.
