Thanks, but we’re living in the real world of pubescent young girls. I know this room very well - after all, I babysit the grandkids twice a week. There is no prospect of changing where the speakers go. The wires are actually buried in ducting within the plaster on the walls, so moving them would be a major undertaking, one I’m sure my son-in-law would not want to do.
The realities of the siting are that due to fitted wardrobes, shelving, windows etc, there is really nowhere to put them other than where they are already.
All I really want is an opinion on the likely sound balance of these speakers in her room. I know that near wall placement doesn’t work well for most speakers (that’s why I like Naim and Linn speakers), but I have figured out that infinite baffle or reflex with the port at the front or side are like likely to be the best options.
The B&Ws, which I have never heard, have front porting, and are the right size. I did consider the Linn Majik 109s for her, but their depth is greater, and would probably not be acceptable, cosmetically.
My own purchases of speakers over the years have been : Wharfedale Meltons, Spendor BC1, Linn Sara, Naim SBL, Royd Edens, Naim n-System (which I still own). I did have a B&W centre speaker at one time, chosen because it had a similar tonal balance to the Royd Edens.
You’d probably not like where my front nSats are situated, but again, the room size and window position dictated that. They work very well where they are situated, BTW.
So - any comments on the suitability of the B&Ws for the room placement?
