Bbc monitors
Before moving to Ovators I had monitors+subs but never managed to make them play well together, the music did not sound coherent.
The Ovators then were a relevation, musical presentation very fast, coherent and voices so clear and tangible like I have never heard before.
I would rather be upgrading amplification than changing speakers.
Careful placement is absolutely critical though for the Ovators as well as ensuring the screws are tightened carefully, they might need re-tightening after they were moved.
Provided the speakers are angled you should not have problems with speakers that have Full Range bass with your room dimensions, i certainly have no problems in rooms of your size.
If you did/do try having one spk at a different dimension from the side wall and at a slightly
different angle to the other one, This can stop the speakers reinforcing each other.
