Although I can see On Demand programs listed in the bbc sounds web page and the iPad can play them they are (after July 7th ish) no longer available via the Naim app.
What have I not done? I miss Night Tracks.
What you have to do is to delete your saved R3, then got to internet radio in the Naim app and then go to BBC, Radio 3 and one of those listed will be Radio 3 HD. Select that and when it’s playing ok, tap the star icon on the now playing page.
I can explain more fulsomely if that isn’t clear.
Thank you David. I will return if Sahrah or Hannah can not be there to comfort me whilst listening abed later tonight.
From another thread:
Hi all,
BBC Ondemand - BBC have discontinued this for 3rd parties, so Ondemand will only be accessible from the BBC Sounds and similar BBC distribution points. VTuner should really remove this section, but while it stays the content available will slowly go as it times out.
Steve Harris
Software Director
Naim Audio Ltd.
Yes, I should have read Nick’s original post more carefully.
Thanks.
I don’t have a tv licence,not that it was ever necessary for radio listening but that is my last link with the bbc dissolved.
Nick
You could use the BBC Sounds app on your phone or tablet and connect to your NDX2 using Chromecast or Apple Play? The BBC Sounds app is easy to use and you will find all the on demand things there easily.
