Perhaps it just cropped up when I did it? I don’t remember it causing a problem. Possibly I downloaded a fix from Microsoft. (I was using my Daughter’s laptop)
Try get_iplayer to download BBC programmes, however, you need to delete the programme after 28 days.
I downloaded.net 2.0 by searching for and then installing it . I then struggled with the laptop because it couldn’t find the streamer as the laptop wasn’t on a wired network. I then moved the streamer to my desktop pc and was finally able to update the firmware. Oh and the BBC On Demand service is working!
Wonderful! Well done solving the .NET 2 problem. It should work on WiFi but anyway I’m pleased it all worked out for you.
