Can’t find this under bbc stations on Naim app, anyone found it?
Terry
Nope, not on RadioBox either.
BBC Sounds only at the moment it seems.
The BBC are only making this available through the Sounds app at the moment. It’s the same with Radio1A. Maybe they’ll allow third party apps to access it at some point, but not now.
It is a low fi stream, so I’d cast it from my phone by bluetooth/ airplay. There are some work arounds as discussed here.
