Well I’ve had the Vispring Tiara Superb with Sovereign divan for 2 weeks now. It’s absolutely wonderful. The most comfortable bed I’ve ever slept in. Should have done this years and years ago. Of course, money is the problem. Too many necessities and luxurious things to buy. A bed isn’t pretty and one doesn’t sit in a main room admiring it as a piece of furniture, so I suspect that’s why I’ve not gone out my way to invest in a good one. I sleep better, don’t toss and turn, and every night, lying on it feels luxuriously soft yet supportive.
Things I’ve learnt/bought for the bed recently:
The more you pay, the better the bed, up to a point where the materials don’t add comfort, they extend the life of the comfort. This bed is at the point in the Vispring range that comfort can’t be matched by the lower priced models.
I’m a side-sleeper. I’ve never really put a great deal of thought into this and always bought a good quality feather/down pillow. I need a pillow to support my head to the right height and apparently need a firm pillow. I would never have particularly chosen a firm one, but it of course makes sense. I bought a Yves Delorme Prestige Firm. This box-edged pillow has an inner chamber of 100% Hungarian goose feather for support and two outside chambers of Hungarian goose down for softness. It’s the same product Brinkhaus sell for £340 as ‘down around firm’ (Yves make them for Brinkhaus), but much cheaper. This is true and correct btw.
I’ve invested in the best low tog duvet I could find too. It’s the Brinkhaus Chalet 3.5 tog. This is filled with 100% large cluster free range white Mazurian snow goose down and uses cotton nano-batiste material for lightness/softness and breathability. The whole king size only weighs 280gr. If you have a top of the range down coat, you’ll know the feeling. Not hot, not cold, not clammy, just comfortable and ridiculously light.
400 thread count high quality cotton sheets/duvet cover are perfect. Not too heavy and breathable.
Use a Vispring mattress protector.
Don’t use fitted sheets.
Turn/flip the mattress once a week for the first month, thereafter once a month for the first few months. Then 2-3 times a year.
Don’t use dust mite protection sheets on the mattress.
Wash cotton sheets at 40c with non-bio powder. Ironing will kill any mites.
Don’t ever wash the duvet. If it’s got to that stage, bin it. Air it outside at least once a week and leave the duvet half folded on the bed first thing in the morning to air the mattress.
As I say, there’s many things one can spend their money on and I should have done it years ago. I wouldn’t spend any less. I would wait, save up, forfeit something. Going to bed now is like an 8 hour pampering session. Matching the correct spring rate to your weight and all the other duvet/pillow details makes it fairly improbable that you’ll sleep in a more comfortable bed anywhere in your life.
