Hello,i have a pair of neat sx2s,i am choosing between the unitilite and superuniti both used,i want to use amp with my tv and also to stream music,cd is not essential,is the superuniti worth the extra 600 pounds?kind regards
Hi, the SX2 are not hard to drive, so I think the Unitilite would be enough for regular listening, but if you like to listen loud, especially in a larger room, you will appreciate the extra power of the SU.
Apart from extra power, there are sound quality improvements with the SU too.
Thak you for your reply,are the units comparable regarding streaming performance?and is using with tv through the optical ok,regards
