Other than the network connection, how would the other digital inputs rank in order from best to worst? SPDIF? BNC?
Naim kit is optimised around coaxial SPDIF, preferably via BNC connection as this will be 75Ohm, rather than RCA. I guess the implementation in the source might have some influence too, but I would try that in preference to optical.
I find that inexpensive cables still give good results for digital connections so it’s easy enough to compare them for yourself.
