LOL, if my house burns down, I’d have a lot more to worry about than whether my music files are saved in a gazillion different places.
Get real, folks. It’s a “first world” problem!
@Dougie thanks!
@ChrisSU You are talking about a strategy and I do agree on that point, but I was simply considering Dougie’s NAS configuration. Won’t you consider Raid 1 as a backup by the way? After all disks are redundant in this configuration.
In the context of a home environment, RAID is of less importance than multiple backups.
We run three NASs, two are “working” - one for general day to day usage (I suppose you could call it “short term”), and one split into virtual drives for Photos, flacs, iTunes etc (more “long term”). It just sits there and occasionally has new stuff added. As it happens, both have twin drives, mirrored (more for historical reasons than anything).
The third NAS (a single HDD of sufficient size) does a daily (incremental) backup of the other two NASs and the D: drives (data drives) on both mine and my wife’s PCs.
OK so NAS3 sits alongside the other two in the server room (aka study/fifth bedroom in estate agent parlance) Not ideal, but if the house burns down then we’re fooked anyway.
I backup the music files on my NAS (Western Digital Reds) to Google Drive. Being in the cloud means I don’t need to worry about reliability and it means I can access my music anywhere.
Question for anyone and perhaps @suzywong and @ChrisSU, who iirc both have Synology.
Any reason for choosing S over Qnap?
Context - I have long had QNAP 4-bay, which needs to be put into semi-retirement as a backup in a different building. Two disks (individually) have failed over time and I am about to update the remaining two, one at a time. Seagate drives, but > 10 years old by date(s) on unit.
IIUC Qnap have had issues over time with cyber attacks. Can of course happen to all os units, but I am unaware if Qnap had / has a specific weakness.
Advice has tended towards sticking with the product known, with which backup would interact maybe more seamlessly.
Is there a clear choice for a particular make?
I would likely be willing to buy 2 new NAS units, one as a back up, same or change?
No particular reason for me, I chose a Synology to run a Unitiserve backup because I knew it was tried and tested, and I think slightly cheaper than QNAP but it was a toss-up between the two.
I tossed a coin .
When I was looking to replace an old malfunctioning LG NAS, I looked at both QNAP & Synology
Hardware performance wise, maybe the QNAP just shaded it.
Software & Apps wise, maybe the Synology just shaded it.
And therefore having bought Synology for NAS1, it was logical to go the same way for 2 & 3.
First: RAID is not a backup. It’s a redundant storage, which increases availability in case of HW (disk) failures.
It does not provide protection against faulty usage (e.g. deleting things by mistake), file system problems, or malicious attacks (like encryption malware). For that, you need an “offline” backup.
Second: if you look at a dedicated, external drive for backups, there’s usually these areas to consider:
The typical options are:
If you want to be more safe with your data, do (at least) 2 backups, with 2 drives. (And possibly store one “elsewhere”, which you only connect now and then. I agree music library recovery after a burnt down house may be 1st world problem, but there can be significant money or time spent on them, so the cost for a 2nd backup drive is not that high. Or include the media into the general IT backup.)
Figure of speech but flood risk for me is real!
As Richard says, HDDs are probably better for backup than SSDs (for now). Backblaze has just begun testing SSD reliability but it will be a while before their data can be compared to HDDs.
Hi all, all of the advise has been greatly appreciated, I have just received a HDD drive from WD, the model I believe is called a My Passport and it’s a 5 TB. Surprised how small the drive is, it took a little over an hour to backup 5,200 items. Just checked the drive and all looks well. Just hope now I don’t need it for some considerable time .
I recommend you have two backups personally. Just in case…
A word of warning over WD’s services. A friend of mine had a WD Home store product and he backed up to WD’s cloud. Something broke in the NAS (not the drive which should be reliable) and it was then that he realised that he had allowed the end of life notifications from WD to pass through his inbox without doing anything else to provide backup.
WD were unwilling or unable to provide access to his backup and just suggested a data recovery company which could take the unit away and try to recover the data from the WD unit itself. The quoted cost was around £1000 just to look at it and quote him for the recovery. He didn’t have the money available to pay that and lost everything.
Personally I will never trust WD again.
I would agree that WD network drives are poor. I tried one a few years ago and it was unreliable as well as having support problems. I don’t think there would be any such problem with a simple portable HDD like the one Dougie has bought, though, and there is no need to use any potentially flaky WD software to run a backup to it.
I would avoid using an SSD for backup, especially if the backup is an important one.
The main reason is that if the SSD fails, you lose everything! It works or it doesn’t work in my experience. SSD’s have a limited number of read/write cycles, although this is very high.
A mechanical hard drive might well be slower, however, if a few sectors break you can still use recovery tools to rebuild it, try that with an SSD!
Well, backing up to one device, whether it’s SSD or a mechanical hard drive or the cloud isn’t really a backup. It’s just a copy that can fail.
If one has a digital library they want to protect, that requires at least two copies to other media, and one should be offsite. Without that, you don’t have valid backups, just copies prone to the same failure as the source.
How true. RAID has even more points of failure. It’s possible for the controller to fail even though the drives are intact, but there is no guarantee that a replacement controller will even recognize the RAID from a failed controller, and it could be a case of good, but useless drives.
RAID is about availability and performance, not fail safety for data.
I run a Synology DS1520+. I use five 14TB Seagate EXOS HDD’s (helium filled & high-MTBF like WD Gold) in a RAID array that can tolerate any two drives failing. I have 2 Samsung 980 Pro 1TB (really 950GB) M.2 drives in a RAID-1 array fr the read/write cache. I set the Synology fans to run in “cool mode”.
I’m a big fan of Seagate EXOS & WD Gold. Only downside is they are both LOUD compared to most other platter type HDD’s.
I use Synology’s Active Business Backup for my Nucleus’s Music library internal SSD backup and the Roon Backup function for the Nucleus OS and SQL database backup.
Very very pleased.
The question was about music library backup, and it doesn’t sound like you have a backup strategy for your Synology NAS, and maybe just your Nucleus?
There are a few misconceptions floating around here. Having been a storage appliance engineer for the past decade and the decade before that constantly in and out of the data centres for some of the largest banks, I’ve seen the failure modes in the field up close more than most.
Ultimately HDD failure rates give me some anxiety whereas SSD don’t. They are consistent, perform well, and have much better MTBF.
