Liking that a lot, very chilled. It’s amazing how good 128k can sound if done right.
I’m absolutely with you on that.
Folk Alley. A great selection of folk/roots/Americana.
I am indeed often amazed how good this station sounds even when only broadcasting in 128kb. Glad you noticed it too!
Great response! I need to try them all !
I occasionally listen to 3WK from St. Louis - Missouri. Discovered them about 10 years. SQ not brilliant but good mix covering blues, jazz, classical, rock, indie, etc, in one of their sub-stations.
I’ve listened to radio Paradise for years too and it’s still in my favorite presets but since I discovered relaxing jazz I haven’t moved from the jazz groove west anymore …
DKFM if you like shoegaze/dream pop type of stuff
Radio Blues
I get local advertising breaking in on some stations, does anyone know if there’s a way to block or prevent this happening? Listening via vtuner on NDX2.
You’ll probably like Klassik Radio: Smooth Jazz too. Nice music to have on in the background when working from home. Like your suggestion there are no adverts.
Antenne Bayern Chillout
Great for background listening (relaxing pop/dance, lounge music) and the sq is pretty impressive for a 128k stream.
Audiophile jazz @ 320 Kbps was my fave, however I think it has been recently blocked, due to court ruling re steaming international radio stations in UK via the likes of tunein radio/vtuner, something to do with Sony?
Nice! Thanks for pointing this station out to me. I find it in the list as Klassik Radio Smooth, but assume that is the correct one.
Yes it is, I just pulled the name out of Roon which I suspect has been subtly altered. There are some other stations in the Klassik Radio series which are worth a try.
Amazing replies, guys!
On a slightly off-topic question…I have a 1st generation MuSo and no intention or need to upgrade it. But, I wondered how people connected to it? I know NAS is “the answer” if you want to hear tunes you’ve collected, but what about internet radio? There are only 6 presets (as far as I can see, please tell me if I’m wrong!) in the Naim app, so I’m using bluetooth to connect “none-preset” stations from my 'phone. But, is that the best way? Is there a better, or different, way?
There are limited presets (Muso Qb so in my case 5) on the unit itself but I think the limit is 40 in the app.
Many radio stations are available through the iRadio button in the app. There is no need for Bluetooth.
Ah. The app / iRadio. Of course! Thank you!
I just wondered…There are, indeed, many stations on the iRadio section of the app. Thank you! Perhaps someone might be kind enough to tell me how I find how to save them “in the app”. PW42 thought there was room for 40??
I’ve tried tapping on the icon / double tapping on the icon / long hold on the icon (that just gives a “play now” option).
Perhaps it’s me??? My MuSo is first generation, perhaps that makes a difference?
Mike
