I’m looking for some advice please. I have a NAC202, NAP200, with a CD5, FlatCap 2, ND5XS, XP5 XS, HI CAP DR, Stageline S, Headline and 2 x NAPSC. Speakers are a pair of SBL’s.
Currently I have the NAC202 powered via the NAP200 along with the NAPSC and the HICAP DR. The ND5XS is powered via the XP5 XS, and the Headline via the other NAPSC. The Stageline is off the FlatCap2 which is also powering the CD5.
Whilst I’m happy with the setup, I wonder if I have the most optimal configuration, I’d love any thoughts on alternatives.
OK, then that’s not correct. If you have both the NAP200 and the HICAP connected to the NAC202 at the same time then performance is impaired and it can also over-stress regulators. Connection of the NAP200 should be to the HICAP from where it take the pre-amp signal. See the connection diagram below;
Further things to look out for; As you have a Naim CD player as well as a Naim Streamer connected to the NAC202, make sure the earthing switch on the ND5XS is set to “floating”, that way you will avoid having two sources with a signal to earth connection connected to the pre-amp at the same time.
Also, have you tried dedicating the Flatcap to powering the analogue output of the CD5 and using the powered AUX2 socket on the NAC202 to connect and power the Stageline? Might be worth trying so the Stageline gets some benefit from the HICAP DR and also from one less i/c in the signal path. The CD5 should sound better too. See how you go here as it may be better as you already have it, but worth trying anyway.
The other think to note is that a Hicap should only power one thing at a time. So the Hicap powers the 202, along with a Napsc. The second Napsc powers the Headline; the headline does not connect to the Hicap at all.
That would be amazing, it already sounds great so an improvement will be fantastic. I’ve just got back into Vinyl so adding in the Stageline and the TT made be just think if I’m making best use of it all. Thanks again
Yes, it definitely gives the CD5 a good performance lift. However, it’s better when the Flatcap is dedicated to just the one item (CD5 in this case) than when it is shared.
