Bluos app - music services - select Qobuz - sign in - Qobuz will then appear on the main Bluos menu. I assume you already have a Qobuz account.
You can skip BluOS altogether. Just open the Qobuz app, swipe down from the upper-right-hand corner of your iPad to instantiate the Airplay icon (which will appear in the upper-right-hand corner of the music widget), select your player (you can rename your player in the BluOS app). I only use the BluOS app to setup the player, not for music.
If using a BT Hub make sure you have turned off Smart Setup in the router!
See: https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
