Can anybody tell me the proper connections for hooking up a Node 2i streamer to my NAC 282. It was a gift from my son as he is not yet into the NDX snack bracket.
Naim 5 pin din to twin co ax.
Any particular connection port on the 282.
I used the tuner input but have also used aux on my 252.
If you happen to have a standard stereo audio cable with RCAs at both ends it will work fine, the 282 has a couple of inputs with RCA sockets.
Naim amps are generally best when used with their DIN inputs, so if you get a 2 x RCA to 5 pin DIN cable that would be ideal. Any spare input will be fine.
As Chris says, this is probably the simplest way if you have some spare RCA cables already. Don’t forget to assign the appropriate RCA sockets to the cd or aux 2 input buttons in place of the DIN sockets if you go the RCA route.
